customer connection
Feb 19th, 2007
I need to give access to the internet to customers while they are waiting in our service department. I have to cross two IDFs that don't support VLAN. how do I give them access and still secure my Lan. I was thinking I could put in a router near customer service location with gateway being my internet router. Would this keep them off my internal network?
john.preves Mon, 02/19/2007 - 12:19
Why not just pay to have a Cable modem put it like the rest of the great unwashed? Stick an AP to that and you should be good.
mpmccarron Tue, 02/20/2007 - 11:12
boss doesn't want to put out the money for extra cable link when there is more than enough capacity on our T-1 to support this project.
Kunal Singh Tue, 02/20/2007 - 04:23
You can place AP in service department. Creat guest vlan on switch add an ACL on switch so that guest vlan user just get access to internet.
[Service AREA]>>>>>AP-----Switch (guest vlan with ACL)------Gateway ISP
This will allow your customer to access internet and also keep them off from internal network access.
On AP
-SSID ( Broadcast) with any security like WEP/WPA-PSK if you like.
-Define guest Vlan
On switch
-Create guest vlan
- Make swtich port as acess port allow guest vlan traffic
- Define ACL to restrict Vlan user access
We are all set.
Kunal
mpmccarron Tue, 02/20/2007 - 11:10
intermediate switch does not support VLAN. I was wondering if putting a router between customer wireless LAN and my interal wired Lan would work
