4506 to Foundry F800 Trunking ?
Feb 19th, 2007
Can anyone assist me with a config for trunking 4 gig ports in an etherchannel setup. I need to create the trunk so I can move boxes off the F800 so I can retire it.
Thanks.
sachinraja Mon, 02/19/2007 - 19:54
Hello Rob,
you just need to enable channel-groups on the trunk interfaces. use either pagp or lacp on the interfaces, with appropriate modes (active/passive/auto or desirable).. Are you doing etherchannel with Foundry switch ? if so, please check the configs on foundry.
With respect to cisco, u can use the following URL for configuring etherchannels:
http://cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a008011c8a9.html
Hope this helps.. let us know if you need anything else in this..
Raj
