Eigrp help plz
Feb 19th, 2007
hi guys, suppose i have 2 routers connected via their 2 serial interfaces like this
router A serial 0 to router B serial 0
router A serial 1 to router B serial 1
now lets suppose i have configured a loopback interface on router b, eigrp from router A will select both serial 0 and 1 to forward packets to tht network means loadbalance, how can i prevent this ?? like i want the packets to go from s 0 not s 1 ???
Harold Ritter Mon, 02/19/2007 - 11:00
You need to increase the metric on interface serial 1. This can be done by either increasing the delay or reducinf the bandwidth of interface serial 1.
Interface serial 1
delay
bandwidth
Hope this helps,
shaila_rox Mon, 02/19/2007 - 23:41
thank u, is there any other way also to do this like thru policy based routing or some other way ?? plz tell me
a.hajhamad Tue, 02/20/2007 - 00:36
Source based routing can be done at your case, but this will be permenant, all the source subnet will be directly forwarded to the required interface.
purohit_810 Tue, 02/20/2007 - 07:37
It is not doing authentication by ACS server, simple pc authentication it is showing. Your PC is not in Domain but remote pc is in domain... that is the reason it is asking for domain.
Please instal server addition and install ACS on it. Please.
After authenticate with domain database, when any user's profile you are creating on ACS server.
Have did above?? Pleaserevert me.
Dharmesh Purohit
