question regrading rip and eigrp
Feb 19th, 2007
hi all
if a network is running both rip and eigrp , if on eigrp "auto summarisation is there" . if router on that network get 2 routes from both rip and eigrp "rip
got = 150.24.5.0 " and eigrp get = 150.24.5.0 "
case : 1
if rip was configured its admin distance as 90 " and eigrp is also admin distance 90 which route will it choose
case =2
if rip admin distance is 120 and eigrp admin distance is 90
case : 3
if i make eigrp "no auto summary "
then via rip that router get "150.24.0.0" and via eigrp that will get "150.24.5.0"
and apply the same above case 1 and case 2 for the above scenario which route a router will choose .
thanks
Richard Burts Mon, 02/19/2007 - 12:11
Case 1: both RIP and EIGRP advertise the same prefix 150.24.5.0 (I assume /24 - if not it may make a difference) and both are configured with the same administrative distance then IOS will choose one of the routes to put into the routing table. I tested this a long time ago and remember that the RIP route was chosen. There was a posting from a Cisco engineer in NetPro a little while back that says that the current behavior is that when there is a tie in administrative distance, that IOS will consider the default administrative distance to break the tie and so EIGRP would be chosen and put into the routing table.
case 2: both RIP and EIGRP advertise the same prefix 150.24.5.0 (I assume /24 - if not it may make a difference) and RIP has distance of 120 while EIGRP has distance of 90. In this case the EIGRP route is chosen and put into the routing table.
case 3: RIP advertises 150.24.0.0 (I assume /16) and EIGRP advertises 150.24.5.0 (I assume /24). In this case it does not matter what the administrative distance is because there are 2 different prefixes and both of them will be put into the routing table. The EIGRP route will be used for any addresses within 150.24.5.0/24 and RIP route will be used for all other addresses within 150.24.0.0/16.
Rick
SPYME.GOOGLE Mon, 02/19/2007 - 12:16
hi rick
thanks for your reply
in case 3 if both rip and eigrp has admin distance 90 and if rip advirtizes 150.24.0.0/16 and eigrp adverstizes 150.24.5.0/24 then which one will be taken. will both router appear in the routing table?
Richard Burts Mon, 02/19/2007 - 12:19
In my previous answer I said clearly that in case 3 both routes are put into the routing table.
Rick
