Remote host and Internet
Feb 19th, 2007
I want to access the remote host from the local office as well as local office and have internet access at the same time.
can i do that using following solution?
is it possible to establish gre tunnel between both the site and forwarding only private ip address data to the tunnel using static route and for othere internet traffice we can use that default router which is pointing to the real ip of interface or to the default gateway of the isp.
sachinraja Mon, 02/19/2007 - 20:00
Yes this is possible. Your PC can have default gateway to the router.. the router can route only the required private subnet over GRE. by doing this, u can access both your remote private subnet and internet.
GRE is easy to configure, but i would never use it, since it sends packets over internet on clear text.. it is not at all secure.. i would instead use IPSEC with 3DES encryption, on a client-server/remote access mode. In this, the client will connect to the remote end VPN server (can be a router/firewall/ VPN concetrator etc).. Once authenticated and connected, he can access any resource on the remote network. If we enable something called "split tunneling" he can access both remote private network as well as internet on the same PC. Only the traffic to the remote office IP will go through the VPN client adaptor. all other traffic will go through the physical NIC, thus allowing both the accesses.
Hope this helps.. all the best.. rate replies if found useful.
Raj
