4507R rspan
Feb 19th, 2007
I have a 4507r with a sup IV (WS-X4515) with cat4000-i9s-mz.121-19.EW1.bin.
The WS-X4515 data sheet says that it supports rspan as does feature navigator. However the command isn't there (conf t, vlan xxx, remote-span).
Is this configured in a different way on the 4507 (the config guide just says "create a remote-span vlan")
Or is it not really supported on what I have
sachinraja Mon, 02/19/2007 - 19:31
Hello chris,
am sure this is supported on the IOS given by you. I also ran a software advisor and saw the support for RSPAN for the 12.1(19) EW1 IOS. Attaching the software advisor output with this post..
I also tested this on other IOS based switches like 3750, and i was able to add the RSPAN vlan with vlan 512 , remote-span command. so, am sure it should work on the 4500's.. can u type the command (might be hidden) and see if it works ?
Raj
