ISDN Alerting before Connect
Feb 19th, 2007
is it possible to send the ISDN Alerting message in front of the ISDN Connect message with a PRI voice-port when a port is used for a two-stage-dialing? I mean some configuration like the "ring number" with FXO voice interfaces.
I have an issue with some PBX that requires to first receive the Alerting and just then the Connect message.
interface Serial2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn send-alerting
no cdp enable
voice-port 2/0:15
description E1_abc
bearer-cap Speech
Thank you.
Paolo Bevilacqua Mon, 02/19/2007 - 16:49
(can you post to IP telephony forum ?)
For "isdn send-alerting", the manual states:
isdn send-alerting
To specify that an Alerting message be sent before a Connect message when making ISDN calls, use the isdn send-alerting command in interface configuration mode. To disable the Alerting information element, use the no form of this command.
However, just like you found, I've verified on latest 12.4T that even if send-alerting is configured, no Alerting is sent before connect.
I suggest that you open a case with the TAC so that a bug is raised and/or a valid workarond provided.
