ATA 186 SRST
Feb 19th, 2007
Hi Folsk, I have an ata 186 running 3.02.03 when the wan fails and srst is in operation the ata 186 fails to revert back to ccm 4.2.1 , the only solution appears to be making a change to the tftp field via web browsing the ata, any ideas thanks Henry
Overall Rating: 5 (1 ratings)
gogasca Mon, 02/19/2007 - 17:15
Hi Henry if other phones are doing the fallback correctly, I would capture an sniffer trace to see if ATA attempts to register to CCM.
Will try to test that in my lab since it the latest load available in CCO.
What is current value for Connection Monitor in CCM?
henry.benjamin Mon, 02/19/2007 - 17:18
Yes teh ip phones all reover ok but this ata does not -- I could try and get a capture tis a remote site and painful, ccm at the moment says registered ? thanks mate
