VPN 3005 upgrade problem
Just upgraded a 3005 VPN from vpn3005-4.7.Rel-k9.bin to vpn3005-4.7.2.J-k9.bin. I have two issues now. The two internal nic's (public/private)are showing the same MAC address - 00.00.5E.00.01.01. I also cannot connect via http anymore. Console login is basically useless as I tried to restore the olf .bin uncessfully. Anyone have any suggestions on what gives and next steps with the MAC ?
Thanks in advance.
Figured out the solutions. HTTP access dis not work after bin upgrade until after clearing IE cache. The MAC issue was resolved after bin upgrade by selecting reboot and ignore config.
After reboot went into quick setup and reconfigured/init network interface. The original MAC's were back on both interfaces.
Cool stuff!
