username and password unit
Feb 19th, 2007
I need to find a unit to put in my network so I can manage my network with user names and password's. Multi.
binoyjosephstanly Tue, 02/20/2007 - 02:04
hello,
you can use ACS 4.1 solution engine, for security and management. which can give you port based security, in switch side you have to enable 802.1x protocol.
there is no description abt your network if you can give more details i wil be able to give some more details.
Rate if it helps.
Binoy
ellis_b Tue, 02/20/2007 - 23:16
what exactly are you looking to manage? if you just want to setup usernames and passwords in a couple devices, you can set them up on each device:
example:
username ccbootcamp priv 15 password iluvcisco
line vty 0 4
login local
that will setup a router or ios based switch to use the username ccbootcamp and a password of iluvcisco via telnet to the device. it will also grant the person enable mode access by default - so be careful with this! i'd suggest putting an ACL on the vty interface for security.
thanks,
Brad Ellis
CCIE#5796 (R&S / Security)
CCSI#30482
Network Learning Inc - A Cisco Sponsored Organization (SO)
YES! We take Cisco Learning credits!
[email protected]
www.ccbootcamp.com (Cisco Training and Advanced Technology Rental Racks)
www.routerie.com (Routing and Switching Forums)
www.securityie.com (Security Forums)
www.voiceie.com (Voice Forums)
Voice: 702-968-5100
FAX: 702-446-8012
