Open protocols
Answered Question
Feb 19th, 2007
A nessus scan was ran on our 6500 that has 2 ssl modules and the followig ports showed open. Can these be disabled, are there any vulnerablilities? What are they used for?
dc (2001/tcp)
dynamid (9002/tcp)
etlservicemgr (9001/tcp)
globe (2002/tcp)
newoak (4001/tcp)
pxc-splr-ft (4003/tcp)
pxc-spvr-ft (4002/tcp)
X11:1 (6001/tcp)
X11:2 (6002/tcp)
X11:3 (6003/tcp)
Correct Answer by Gilles Dufour about 9 years 7 months ago
http://www.cisco.com/en/US/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a00801f33c4.html#wp1254193
2001,2002 and 2003 are used to display debug messages.
The other ports also have a use to display engineering data.
You can't really attack the SSLM on those ports, but you should normally block all traffic going to the SSLM management interfaces except SSH/Telnet.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Tue, 02/20/2007 - 11:18
Gilles.
