Routing issue
Feb 19th, 2007
In cisco switch 3640 we have two routes as below:
192.168.40.0 via tunnel0
192.168.0.0 via serial1
Now I want to ask that , if traffic comes into switch for route 192.168.40.0,would it not be routed via serial path, or traffic destination 192.168.0.0. routed via tunnel.. how do I specify exact path when such scenario comes ?
mrinmoy.m Mon, 02/19/2007 - 20:43
What is the netmask declared for the subnet whose routing is pointed towards the tunnel0 interface? If it is /24 it will take the Tunnel0 interface, as longest match is preferred first.
Routing thru the serial0 has been done for /16. So it is not the prepared path.
blue4cisco Tue, 02/20/2007 - 01:14
Ok that's fine.. My one question is Can we put traffic on priority based on protocols like I want to set priority to UDP packets in cisco switch 3600
kunalpurk Wed, 02/21/2007 - 00:56
U can definitely prioritise the traffic using QOS.
Define an access-list where in u will match any traffic using UDP service.
Then create a class map and match the access list in that. after that create a policy map where u will have to match the class map which u have defined in the earlier step.
After that, within in the policy map , u will have to prioritise the traffic either using DSCP or using IP precedence. The DSCP value ranges between 0-63 with 0 being the lowest and 63 being the highest. the higher the value , the more is the priority. The same is the case with IP precedence also. However, in IP precedence , the value ranges between 0 - 7.
Finally u will have to apply the poicy map in the outgoing interface as SERVICE POLICY OUTPUT.
Hope this will serve the purpose.
Pls rate the post.
