CCM 4.2 to Gatekeeper Registration
Feb 19th, 2007
I can get callmanager to register with Gatekeeper but I cant seem to get it to register its E.164 numbers.
I have configured everything the way any guide states for me too.
I was just wondering if there were any ideas what I might be missing.
Cheers,
John
Overall Rating: 5 (1 ratings)
Chris Deren Tue, 02/20/2007 - 05:16
CCM does not register its e164 addreses with the GK, CME does.
With CCM your best option is to use tech-prefix or if you only have one cluster you may use default-tech-prefix. There are other workarounds, for example you can change couple of service paramters and then configure static aliases but that may become hard to manage.
HTH,
Chris
