Subnet mask 255.255.255.255 assigned to VPN client - can't ping LAN
Feb 19th, 2007
I configured PIX 501 with PPTP VPN to connect to the small office (PIX FW, Win 2000 Server, several Win clients, LAN IP 10.0.0.X/24):
ip local pool mypool 10.0.0.101-10.0.0.105
vpdn group mygroup accept dialin pptp
vpdn group mygroup ppp authentication mschap
vpdn group mygroup ppp encryption mppe 128 required
vpdn group mygroup client configuration address local mypool
vpdn group mygroup client configuration dns 10.0.0.15
vpdn group mygroup pptp echo 60
vpdn group mygroup client authentication local
vpdn username xxxx password *********
vpdn enable outside
I can connect to the office using Win VPN client, but I can't ping any hosts in the office network. I suspect that the reason for that is subnet mask assigned to the VPN client: 255.255.255.255. ipconfig of the VPN client:
PPP adapter Office:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 10.0.0.101
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . :
Default GW is missing too, but I think this is not the main problem.
Any way, what is wrong with my config? How to fix subnet mask assigned to clients? Or may be my assumption is wrong and this mask is ok? What is wrong then?
Any input will be greatly appreciated!
George
mrmozaffari Mon, 02/19/2007 - 23:13
When you connect to pix through vpn the assigns an ip address , a subnet mask and Default Gateway the 255.255.255.255 mask is normal like when you connect through your modem to an async line but here there is no Default Gateway and may be it is cause of your problem.
Can you send your pix configuration ?
Best Regards B.Mozaffari
concordia1999 Tue, 02/20/2007 - 05:12
Thanks for the prompt reply.
Here it does:
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxx encrypted
hostname OSTBERG-PIX
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 80 permit ip 10.0.0.0 255.255.255.0 10.0.20.0 255.255.255.0
access-list inbound permit icmp any any
access-list inbound permit tcp any any eq pptp
access-list inbound permit gre any any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 66.189.xxx.xxx 255.255.252.0
ip address inside 10.0.0.23 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 10.0.0.0 255.255.255.0 inside
pdm location 10.0.0.15 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group inbound in interface outside
route outside 0.0.0.0 0.0.0.0 66.189.yyy.yyy 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
telnet 10.0.0.23 255.255.255.255 inside
telnet 10.0.0.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn username ********* password *********
vpdn enable outside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:xxx
: end
There are remnants of old config, I just recently took over this network, some lines look odd to me, but I did not touch what works. VPN config is all mine.
PIX internal 10.0.0.23 - is a gateway for the network. DNS server in LAN - 10.0.0.15.
I've been reading about the problem and came across several posts that this subnet mask is normal, but it puzzles me - how can this host communicate with anyone else if there is no room for other hosts in this network (according to the mask)?!
Thanks again!
George
