Cryptographic IOS versions on Catalyst Switches
magurwara
1. Where can one find the differences between Catalyst switch IOS with cryptographic features and without cryptographic features?
2. In order to access Cat switches over SSH and HTTPS, do we require Cryptographic versions of the Cat IOS?
3. What does "k9" stands for in IOS names? e.g. "3560-ipservicesk9"
mrmozaffari
Answer to Q1 :
Best plase to compare the Catos and IOS is
www.cisco.com/go/fn
there you can search by ios names or platforms or features and compare images.
Answer to Q2 :
Yes you need Cryptographic version
Answer to Q3 :
K9 stand for Cryptographic version if you have ipservicesk9 you can do SSH in the feature navigator if you search the ios without K9 you will find this :
IP SERVICES W/O Crypto
that means this catos does not support Cryptographic.
Best Regards Bahman Mozaffari.
Please Rate if Helpful.
