VPN from 1841 to 7206
I have been given details for a VPN setup that we use to connect to a GPRS network. We are currently using a Linux IPSec Software solution but I'm now provisioning an Integrated Services Router 1841. I am a little unsure of how to create the VPN in our 1841 to connect. The remote side is using a 7206 but they will not supply a config for us to use. Details are;
Phase 1 (ISKAMP)
Encryption: 3DES
Hash: MD5
Auth: PSK
Diffie-Hellman: 2
Lifetime: 86400
Phase 2 (IPSec)
Transform-Set: ESP-3DES-MD5
Mode: Tunnel
PFS: No PFS
Lifetime: 4608000kB/3600sec
Attached is a diagram with public IPs changed. Can anyone offer some help with this? I am not sure whether I will need to use Crypto Maps and whether I will have to use ACLs
marvin00001 Tue, 02/20/2007 - 00:25
Hi Andrew
the easiest way to do this is to create a GRE Tunnel on each side and then encrypt the tunnel with an IPSEC profile.
Let Me know if you need an example config
Marvin,
The only problem with this solution is that the GRE tunnel requires another subnet over it, correct? I am using this sort of configuration for connectivity between branch offices, however I have no control over the configuration of the 7206 as it is run by Vodafone. When we asked for a configuration example, they said they don't give out configuration details apart from PSK and ISAKMP and IPSEC config requirements :(
