VPN Issue
Feb 19th, 2007
When I connected my adsl router and got ip address is 10.1.1.1/8 then I use remote access vpn terminating on firewall then authentication work fine and got ip address from the pool is 10.7.0.1/16 but I can't access local lan from this if I dialed-up from my pc and got ip address 2x2.102.x.y then I connected remote access vpn and authentication I can access local lan no problem.
It is routing issue on pc with overlap ip or not ???
Thank in advance
ggilbert Wed, 02/21/2007 - 11:59
When you mean local LAN, do yo mean the LAN network on the head end side or the LAN network on your local side.
To answer your question, yes, overlapping IP is the problem.
