2 adsl dialers on the same router
Feb 20th, 2007
hey,
i have 2 adsl lines i need to connect to 1 router. i can't change the pvc number or take 1 big line. i also need to have load sharing between the lines.
so far i did so by 2 vrfs - only way the lines work together, because of the same pvc as far as i know. i ran bgp and then i could route between the vrfs, but i can't ping to the dialer if it's in different vrf.
can someone help? thanks.
purohit_810 Tue, 02/20/2007 - 11:14
Can you give me some configuration and digram what you have did??
Dharmesh Purohit
blacktulip Thu, 02/22/2007 - 06:33
the configuration is followed, the diagram is attached.
the weird thing is i can route between different vrfs except for the dialer, which can be reached only from the same vrf.
configuration:
no ip domain lookup
ip domain name *****
ip name-server ***.***.***.***
ip dhcp pool 1
ip vrf LAN
rd 300:1
route-target export 300:1
route-target import 300:1
route-target import 100:1
route-target import 200:1
ip vrf vrf1
rd 100:1
route-target export 100:1
ip vrf vrf2
rd 200:1
route-target export 200:1
ip audit po max-events 100
interface Loopback0
ip vrf forwarding vrf1
ip address *****
interface Loopback1
ip vrf forwarding vrf2
ip address *****
interface Loopback2
ip vrf forwarding LAN
ip address *****
interface ATM0/0
ip address ******
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/48
pppoe-client dial-pool-number 1
interface FastEthernet0/0
** TO LAN ***
ip address *****
ip nat inside
speed 100
full-duplex
interface ATM0/1
ip address ****
pvc 8/48
pppoe-client dial-pool-number 2
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
ip cef accounting non-recursive external
ip nbar protocol-discovery
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username *******************
interface Dialer2
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
router bgp 1
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf vrf2
redistribute connected
no auto-summary
no synchronization
exit-address-family
address-family ipv4 vrf vrf1
no auto-summary
no synchronization
exit-address-family
address-family ipv4 vrf LAN
no auto-summary
no synchronization
exit-address-family
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 2 interface Dialer2 overload
ip nat inside source route-map adsl1 interface Dialer1 vrf vrf1 overload
ip http server
no ip http secure-server
ip classless
ip route vrf LAN 0.0.0.0 0.0.0.0 Dialer1
ip route vrf vrf1 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
access-list 2 permit any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map adsl2 permit 10
match interface Dialer2
route-map adsl1 permit 10
match interface Dialer1
end
