Configure MGCP BRI for FAX
Feb 20th, 2007
i have a 2801 with a vic2-2bri and 4fxs voice ports.
Also the ccm is 5.0(x) and the gateway is configured as MGCP (I just hate MGCP for these simple implementation but i found it configured and i didn't want to change it!!Otherwise i would use H323 which i think behaves better)
A specific number that hits bri, gets translated and points to the faxmodem attached at the fxs. So i guess there is no conversion to voip?
This scenario works fine with voice (no extra congif needed with an analog phone attached to the FXS) but
in order to receive/send fax with no problems, is there something else i must add in:
Bri port config via CCMadmin page?
fxs port config via CCMadmin page?
bri port in IOS?
fxs port in IOS?
MGCP config in IOS?
Anthony
msolak Fri, 02/23/2007 - 14:47
anthony,
do you have the commands:
"network-clock select" and "network-clock-participate".
These commands are very important to send/receive faxes adequate.
regards
mehmet
