Restore BARS Backup
Feb 20th, 2007
we work on an upgrade from our callmanager cluster from 3.3(4) to 4.2(3). To test the upgrade we plan to set up a preproduction. The preproduction has its own subnet and a different naming convetion. It is possible to import the callmanager backup from the running publisher to the preprod publisher? (they have different names cmp1 / cmt1 and different IPs 172.29.xx.xx / 10.29.xx.xx)
Or is it possible to take a disk out of the RAID1 of the publisher, insert it to the preprod publisher and change the Name and the IP in the CallManger config?
Thank for a feedback
Reto
Overall Rating: 4 (1 ratings)
mchandak Tue, 02/20/2007 - 06:34
On CM the hostname cannot change. The restore should be on the box with the same hostname.
Regarding IP Address, I'd recommend that you restore it on the server with the same IP Address and once the restore is complete, change the IP Address.
HTHs
