about ntp source address
Answered Question
Feb 20th, 2007
Do you know if is possible to use an ip address (loopback 0) that belong to a VRF as ntp source address?
I have this doubt because the NTP server is reachable by ping and at the moment i'm not able to synch both my 6509 and 3560...thanks a lot
Simone
Correct Answer by Tsasbrink about 9 years 7 months ago
Yes,
This is very possible as a matter of a fact i use this on my own ISR.
Can you reach the ntp server witch icmp with an extended ping sourced from the loopback interface ?
Overall Rating: 5 (1 ratings)
Correct Answer
Tsasbrink Tue, 02/20/2007 - 02:53
Yes,
ogadri Tue, 02/20/2007 - 04:51
Yes I can.
I've cheched and in the ntp server command was missing vrf (name of vrf).
thanks again
simone
