Unity IP Fax
Answered Question
Feb 20th, 2007
1) Is it possible to use Unity IP Fax in a VM environment or you need licenses of UM?
2) The idea of this tool is to convert the Unity in a fax server?
Correct Answer by lpezj about 9 years 7 months ago
Raquel,
I think that you need licenses of UM to get fax capabilities.
In this situation Unity receives faxes as emails, so you have a gateway to a fax server. I have made tests with Rightfax and Exchange and you need a conector in Exchange that it sends the faxes to Unity as emails. Then you can send faxes from Outlook to a fax number using the fax server through the conector set up in Unity.
Hope this helps,
Juan Luis
Overall Rating: 5 (1 ratings)
Correct Answer
lpezj Tue, 02/20/2007 - 02:24
Raquel,
Hope this helps,
Juan Luis
