Error in IOS upgrade 7613 Router
Feb 20th, 2007
Hello all;
I am trying to upgrade my IOS first I am trying to have a copy of the IOS but I get this error, this is a 7613 Router
ShRo001#copy sup-bootflash: ftp://administrator:letmein@10.0.x.x
Source filename [s72033-psv-mz.122-18.SXD3.bin]?
Address or name of remote host [10.0.x.x]?
Destination filename [s72033-psv-mz.122-18.SXD3.bin]?
%Error opening sup-bootflash:s72033-psv-mz.122-18.SXD3.bin (No such device)
ShRo001#
ShRo001#
ShRo001#
ShRo001#sh sup
ShRo001#sh sup-bootflash: all
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1 .. image A1E2806A 2BD10D4 29 45420628 Feb 24 2005 03:25:17 -08:00 s72033-psv-mz.122-18.SXD3.bin
20115244 bytes available (45420756 bytes used)
-------- F I L E S Y S T E M S T A T U S --------
Device Number = 2
DEVICE INFO BLOCK: bootflash
Magic Number = 6887635 File System Vers = 10000 (1.0)
Length = 4000000 Sector Size = 80000
Programming Algorithm = F Erased State = FFFFFFFF
File System Offset = 80000 Length = 3E80000
MONLIB Offset = 100 Length = A978
Bad Sector Map Offset = 7FFF0 Length = 10
Squeeze Log Offset = 3F00000 Length = 80000
Squeeze Buffer Offset = 3F80000 Length = 80000
Num Spare Sectors = 0
Spares:
STATUS INFO:
Writable
NO File Open for Write
Complete Stats
No Unrecovered Errors
No Squeeze in progress
USAGE INFO:
Bytes Used = 2B510D4 Bytes Available = 132EF2C
Bad Sectors = 0 Spared Sectors = 0
OK Files = 1 Bytes = 2B51054
Deleted Files = 0 Bytes = 0
Files w/Errors = 0 Bytes = 0
******** Intel SCS Status/Register Dump ********
COMMON MEMORY REGISTERS: Bank 0
Intelligent ID Code : 89898989
Compatible Status Reg: 80808080
DEVICE TYPE:
Layout : Quad x8 Mode
Write Queue Size : 64
Queued Erase Supported : No
ShRo001#
Ahmed Elnagar Tue, 02/20/2007 - 06:04
It is the same problem
ShRo001#copy sup-bootflash:s72033-psv-mz.122-18.SXD3.bin ftp://administrator:letmein@10.0.x.x
ShRo001#copy sup-bootflash:/s72033-psv-mz.122-18.SXD3.bin ftp://administrator:letmein@10.0.x.x
%Error opening sup-bootflash:/s72033-psv-mz.122-18.SXD3.bin (No such device)
ShRo001#
I will tell you my steps that let me in this status;
first I took a copy using the ftp and It was sucessful then I erased the files from the slavesup-bootflash (on standby sup.) to upgrade this first, and when I try to copy from the ftp it hangs and no response, even my console session to the active sup is freezed and I am only telneting on the Router.
by the way the same problem happens with tftp and also when I try to copy from the supbootflash to the slavesup-bootflash. I cannot reload the router as it is on a production network now.
any suggestions?
