Extension Mobility - Tomcat
Answered Question
Feb 20th, 2007
Hi, I am trying to install Extension Mobility on a CCM 4.1(2) server and after starting the service on the control centre, I am having problems getting into Tomcat. It is asking for a username and password but it is not accepting any of the admin level user details. Could anyone advise on how I can access Tomcat, thanks, Ian
Correct Answer by rob.huffman about 9 years 7 months ago
Hi Ian,
This sounds like you may be hitting this bug, it is not exact (4.1(2) vs 4.1(3)) but everything else is so similar its scary. Have a look;
CSCse45530 Bug Details
Headline Cannot login into Tomcat Web Application Manager
First Found-in Version 4.1(3)
First Fixed-in Version 4.2(2.202), 4.2(3.6), 4.1(3)SR04, 4.2(1)ES33, 4.1(3)ES83
Symptom:
When trying to login into Tomcat Web Application Manager, the popup menu for username and passwords keeps appearing, despite the authentication succeeded.
Conditions:
This happens all the time when trying the access to callmanager/manager/list, normally after a fresh install and never worked before.
Workaround:
None.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Tue, 02/20/2007 - 10:56
Hi Ian,
Symptom:
Conditions:
Workaround:
None.
Hope this helps!
Rob
