Deleting device in DCR.
Feb 20th, 2007
Is it possible to delete devices in DCR? I have a lot of Discovered devices in Campus Manager that I would like to delete.
David Stanford Tue, 02/20/2007 - 06:55
You can delete devices from the DCR by going to Common Services - Device and Credentials - Device Management
Then select the device you want to delete and select the delete button
This will remove the device from the DCR
radsundas Tue, 02/20/2007 - 20:11
This would be a very simple information still,
DCR is the centralised repository for all the LMS apps. A device cannot be managed in any of the applications like CM,DFM, RME, CV without adding them to DCR.
When you delete devices from DCR you will have that device deleted from all the other applications in the server.
If you know what are the devices to be deleted and are scattered, You can find some commonality (group rule)among the devices and create a CS group with that rule and delete all of them at once.(Eg, "IP address begins with 10" etc)
Radhika
