Unity express auto attendant forwarding problem
Answered Question
Feb 20th, 2007
Hi all,
its configured unity express and cme 0n the same 2851 router
CME [Version=4.0(3)]
Version 4.0(3)
Mode is srst
Max-pool is 96
Max-dn is 288
Cisco unity Express(CUE) Ver info
Installed Packages:
- Installer 2.1.3
- Bootloader (Primary) 2.1.2
- Infrastructure 2.1.3
- Global 2.1.3
- GPL Infrastructure 2.1.3
- Voice Mail 2.1.3
- Bootloader (Secondary) 2.1.2
- Core 2.1.3
- Auto Attendant 2.1.3
Installed Languages:
- English language pack 2.1.3
Confiured outside caller will routed to AA pilot number and after welcome,it willl ask dial the extension(default welcome method).The problem if the outside person dial number assigned to all 7960 ip phone ,it will work properly.But if the dialed number is assigned to 7911 it will not work"the caller will get message saying"you are dialed an invalid number"
Have any can put some lights
thanks
Tom
Correct Answer by Markus Schneider about 9 years 7 months ago
Does the 7911's number actually exist in the CUE config? I.e. if you do a 'show run | inc phonenumber' on CUE, does it match the 7911's extension that you're dialing?
Does dial-by-name work for that user?
Overall Rating: 5 (1 ratings)
Correct Answer
Markus Schneider Tue, 02/20/2007 - 07:59
