CME with SIP
I am connecting a cisco 2811 ios 12.4(11)XJ with callmanager express to a UK SIP provider voipfone.
The problem I am having is that, I can make calls to any voipfone numbers but calls getting disconnected as soon as I call a landline or mobile....
I have added the relevant config below:
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
voice translation-rule 1
rule 1 /^05600040277$/ /1001/
rule 2 /.*/ /1002/
voice translation-rule 2
rule 1 /^9*/ //
voice translation-rule 3
rule 1 /.*/ /08704711587/
voice translation-profile Incoming-Sip
translate called 1
voice translation-profile SIP
translate calling 3
translate called 2
dial-peer voice 1000 voip
description Inbound Dialpeer usinng voipphone
translation-profile incoming Incoming-Sip
preference 1
answer-address 05600040382
destination-pattern 1...
voice-class codec 1
session protocol sipv2
session target dns:sip.voipfone.co.uk
incoming called-number 05600040382
dial-peer voice 10 voip
description #outgoing peer#
translation-profile outgoing SIP
destination-pattern 9T
voice-class codec 1
dtmf-relay cisco-rtp h245-alphanumeric h245- signal rtp-nte sip-kpml sip-notify
I also tried using different codec as below:
codec g711ulaw, g711alaw etc
and that did not help either.
Please can you let me know if I am doing something wrong?
I am also attaching a output from debug ccsip messages when the lines are getting cut.
Many thanks
Anwar
Overall Rating: 4 (2 ratings)
Paolo Bevilacqua Tue, 02/20/2007 - 08:45
The provider does not specify a reason why the call is cut, I can only suppose it's because lack of proper authentication.
Please configure sip-ua and put the appropriate username/password/realm in there, together with any other needed option.
Then collect debuc ccsip message again.
Many thanks for the reply.
I think you are right...If I do a show sip-ua register status, I do not see anything. I was expecting to see the proder sip registration, correct?
Thing that is confusing me is how am I able to make calls to a local number that belongs to the sip provider, voipfone.. I have attached a debug ccsip messages for a voipfone number (not breaking out to PSTN)
Also, I get the following from debug ccsip error when I dial out...
CME01#debug ccsip error
SIP Call error tracing is enabled
CME01#
Feb 21 09:21:01.395: //13/AC76EBF48024/SIP/Error/sipSPIProcessCallInfoHeader: Ca
ll-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
Paolo Bevilacqua Wed, 02/21/2007 - 01:30
Registration is not needed for placing outgoing calls. It is merely a mechanism to tell the provider, send calls to the number I register, here.
By default, IOS will try to register all the POTS dial-peers and number for ephone-DN.
Perhaps you are able to place some calls because these are free, although I do not see a connect message in the debug you sent.
Thanks.
I finally managed to register CME with another provider sipgate and able to make outbound calls. (Voipfone with the same settings) does not register.
Few modifications I had to make to get it work properly. Thoght I should let you know. The dial peer and the ephone-dn needs a reference to the my sipgate account number as below:
preference 1
session target dns:sipgate.co.uk
dtmf-relay rtp-nte
codec g711ulaw
clid network-number SIPGATE_ACCOUNT
no vad
ephone-dn 57 dual-line
number 1003 secondary SIPGATE_ACCOUNT no-reg primary
name Andy
Many thanks for your help.
I am now having problem with DTMF. Any idea how I can troubleshoot this? I am using rtp-nte in the dial-peer as you can see.
Paolo Bevilacqua Sat, 03/03/2007 - 12:51
good to know basic calls are working now. Have you tried "dtmf-relay sip-notify" ? Perhaps is what the ITSP wants. To debug, enable "debug ccsip messages".
Paolo Bevilacqua Tue, 03/06/2007 - 09:07
I was looking at your traces, expecting to see the SIP NOTIFY messages, but I don't,
Let me dig deeper into this, verify few things, and I will be back to you.
Paolo Bevilacqua Thu, 03/08/2007 - 10:51
I found that with "dtmf-relay rtp-nte", I can send DTMF from a SCCP phone to SIP phone.
Instead, "dtmf-relay sip-notify" does not work and no SIP messages are generated in debug.
I think the issue can be the same with a SIP provider instead of SIP softphone.
I suggest that you open a case with the TAC to better understand what is happening.
