ACL restriction on switched network
Feb 20th, 2007
Hi gents,
Which type of ACL should i use to get some ip subnets in restricted L2(swithed) environments?
I cant use mac ACL, as i have a lot hosts.Can't use VLAN ACL either.There are
some restrictions.
thanks
Leo
Leo_Stobbe Wed, 02/21/2007 - 01:19
I have SwitchA connected to SwitchB.
They connected to each other through switched port (access port)vlan 20.
There are a some servers in Vlan20 connected to SwitchB
SWitchB has the route to ISP.
SwitchA- Interface Vlan 20
ip address 10.20.0.1
default gateway - 10.20.0.254
SwitchB - Interface Vlan 20
IP address 10.20.0.254
default gateway - Internet Gateway
SwitchA has vlan16 - 10.16.0.0
Hosts from this subnet access the internet through SwithB and then SwithA.(and also can see servers in vlan 20)
SwitchB- doesn't have vlan 16
It has has onlu back route to that subnet.
How can i restrict 10.16.0.0 access to 10.20.0.0 servers?
Outbound ACL on interface Vlan20 SWitchB?
thanks?
Leo_Stobbe Wed, 02/21/2007 - 01:21
Sorry...Correction.
Hosts from this subnet access the internet through SwithA and then SwithB.(and also can see servers in vlan 20)
Outbound ACL on interface Vlan20 SwitchA?
Jon Marshall Wed, 02/21/2007 - 03:19
Hi Leo
Do you have an SVI on switch A or vlan 16 then ? I guess you must be. You could apply the following acl on vlan 16 on switch A
access-list filter deny ip 10.16.0.0 255.255.0.0 10.20.0.0 255.255.0.0
access-list filter permit ip 10.16.0.0 255.255.0.0 any
On vlan 16 interface
ip access-group filter in
The destination network from the 10.16.x.x hosts will be always be allowed unless it is going to a 10.20.x.x address.
If there are some addresses in the 10.20.x.x range that you want access to from 10.16.x.x clients you could add those to the top of the access-list.
Jon
jain.nitin Wed, 02/21/2007 - 02:24
Hi, apply extended ACL on vlan 20 interface as inbound & define 10.16.0.0 as source & destination 10.20.0.0.
If it helps do rate it.
Ninja
