IP NAT/route-map Experts, what does this mean to you...
Feb 20th, 2007
I'm having troubles following this logic; what does this ip nat and route-map combo actually do?
ip nat inside source route-map nonat interface Vlan20 overload
access-list 140 deny ip any any
route-map nonat permit 10
match ip address 140
Thanks for your help.
Dennis
Overall Rating: 4 (1 ratings)
Jon Marshall Tue, 02/20/2007 - 10:02
Hi Dennis
As far as i can tell it's not really doing anything.
The nat statement says to NAT everything to the Vlan 20's ip address only if it is permitted in the route-map. But the route-map only has a deny ip any any statement in it so all packets will not get natted as far as i can see.
Jon
dmorassut-sbi Tue, 02/20/2007 - 10:14
Thanks Jon. That's what I'm begining to think as well. Also based on this info...
sh access-lists
Extended IP access list 140
10 deny ip any any (3858277 matches)
PHX-CHA-2801#sh route-map all
STATIC routemaps
route-map nonat, permit, sequence 10
Match clauses:
ip address (access-lists): 140
Set clauses:
Policy routing matches: 0 packets, 0 bytes
PHX-CHA-2801#sh ip nat stat
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
Virtual-Access1, Dialer1
Inside interfaces:
Vlan10, Vlan20
Hits: 0 Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] route-map nonat interface Vlan20 refcount 0
Queued Packets: 0
I found that config in a router and was having a challenge understanding what was being done.
Dennis.
