IPSEC MTU size should be 1500 or 1400 with ipsec 60 overhead?
Feb 20th, 2007
Our l2l vpn connections have different MTU sizes. The VPn connection is established but I only get inbound traffice but no outbound traffic. Should the path mtu be 1400 or 150 for the VPN?
1400, ipsec overhead 60, media mtu 1500
hoogen_82 Tue, 02/20/2007 - 11:17
Just keep pinging the other end ip address with ping x.x.x.x -f -l 1500.
Keep decreasing it untill you get replies back. The time you get reply is probably the MTU you would want to use.
Hoogen
