Cisco 2821 How to create VLANS ?
Feb 20th, 2007
Real stupid question for me but I have to ask. I have a Cisco 2821 unit and I'm trying to create vlans; non of the normal commands (set vlan, int vlan etc) are accessible. I can access the vlan database and set names, but no ip's etc?
The unit is a cisco 2821 with a NME-16ES-1G-P card with IOS 12.4(2)T5
Any pointers would be much appreciated.
Ed
sundar.palaniappan Tue, 02/20/2007 - 11:09
Ed,
I assume you want to configure VLAN interfaces, aka SVIs, to route traffic between the VLANs. In that case, try this;
int
encapsulation 1 --> where 1 is VLAN1. Set the encap to dot1q or ISL based on what trunking encap is set on the switch the interface is connected to.
ip address x.x.x.x/xx
int
encapsulation 2 --> where 2 is VLAN2.
Instead, if you had a different requirement can you clarify what exactly you want to do and we may be able to help you.
Sundar
edw Tue, 02/20/2007 - 12:35
Thanks for the reply. I used to use set vlan commands. New to the whole 12.4 stuff. which f0/0.1 interface is it to config ? surely I should be using interface vlan 1 etc ??
I am simply trying to create a set of vlans on the router to use on the switches connecting to it.
Ed
sundar.palaniappan Tue, 02/20/2007 - 12:45
Add the VLANs from the VLAN database. The output below is from a 3725 router. I am sure the command structure on a 2800 is similar to this one.
R5#vlan data
R5(vlan)#vlan 5 name test
VLAN 5 added:
R5(vlan)#apply
APPLY completed.
R5(vlan)#show
VLAN ISL Id: 1
Media Type: Ethernet
VLAN 802.10 Id: 100001
State: Operational
MTU: 1500
Translational Bridged VLAN: 1002
Translational Bridged VLAN: 1003
VLAN ISL Id: 2
VLAN 802.10 Id: 100002
State: Operational
MTU: 1500
VLAN ISL Id: 5
VLAN 802.10 Id: 100005
State: Operational
MTU: 1500
Sundar
edw Tue, 02/20/2007 - 13:10
Thanks - but how do I then assign the ip address for vlan gateway ? IE for gateways for the PCs on the vlan etc ?
Ed
sundar.palaniappan Tue, 02/20/2007 - 13:21
There are two ways you can configure a router/layer 3 switch to route traffic between VLANs. You can configure VLAN interfaces, aka SVIs, if your router supports it. The command to configure SVI is 'int vlan (#)' from the config mode. Or, if the router doesn't support SVIs then you need to configure sub-interfaces like I had mentioned in my previous posting.
Sundar
edw Tue, 02/20/2007 - 15:26
Thanks for the help. WHat Im finidng difficult is where do I assigned the ip for the vlan itself. The email re int fa0/0.1 - doesnt this mean im assigning a ip address to the port rather than the vlan ?
Ed
sundar.palaniappan Tue, 02/20/2007 - 15:47
You don't assign an IP to the VLAN itself. When you create a VLAN from the VLAN database mode all you are doing is making the switch aware of a broadcast domain. Then, you assign switch (layer2) ports to that VLAN. To route traffic between the VLANs you need a layer 3 interface, like SVI or sub-int, and that's where you apply the IP address. Hope I made it clear.
Sundar
edw Tue, 02/20/2007 - 16:56
Thanks again - yep understand that. Ive being using C6006 Routers so used to the set vlan command structure.
The bit I'm mis understanding is the sub-int part - which interface should the vlan be under IE my 2821 unit has two gigabit ports and also a 16 port netowrk module which is viewed as another gigabit port... so where do I configre the vlans as sub interfaces ??
Ed
edw Wed, 02/21/2007 - 05:19
Thanks - Im having a problem with VTP now thou - I have configured the Giga1/0 as vlan 1 with ip and then 1/0.1 as vlan 2.
Set the router to server with domain name and then swtich card to client with domain name and its not proagating ??
Help im confused - dont have this problem on my boxes - why does cisco change the commands for the SMB boxes - its pointless..
Ed
edw Wed, 02/21/2007 - 05:54
Well, unfortantly if I don't the switch doesnt work and I can access the switch IOS in on the card ????? Then when I try to apply another ip on the vlan 1 range it complaines its overlapping ??
Using 1219 out of 245752 bytes
version 12.4
hostname R-CORE-01
boot-start-marker
boot-end-marker
enable secret 5 $1$YOGa$gQdMjrhxhzHFVbHZ1RI9j1
enable password Mother2
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
interface GigabitEthernet0/0
duplex auto
speed auto
vlan-range dot1q 1 3
exit-vlan-config
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet1/0
no ip address
no mop enabled
interface GigabitEthernet1/0.1
encapsulation dot1Q 1 native
ip address 10.1.1.254 255.255.255.0
no snmp trap link-status
interface GigabitEthernet1/0.2
encapsulation dot1Q 3
ip address 10.3.1.254 255.255.255.0
ip classless
no ip http server
dialer-list 1 protocol ip permit
I have connected a switch to the gi0/0 port as well and VTP is not sync with that oe either ???
VTP Version : 2
Configuration Revision : 2
Maximum VLANs supported locally : 48
Number of existing VLANs : 13
VTP Operating Mode : Server
VTP Domain Name : JOY
VTP Pruning Mode : Disabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0x11 0x3F 0xA6 0xF3 0xDF 0x2C 0xCF 0x1B
Configuration last modified by 10.1.1.11 at 2-21-07 13:09:48
Local updater ID is 192.168.1.1 on interface Gi0/0 (first interface found)
Ed
