Links from 2 ISPs
HI EXPERTS!
Kindly,have a look to the attached diagram;as well as to the Config provided from Devang!
i have 2 wireless connection from 2 different ISPs(ISPA;ISPB)ISP A Terminate link at R1;ISPB Treminate link at R2;i want to achieve the following setup:if the first Link(ISPA)fail the second link (ISPB) TAKE OVER.R1 ITS PRIMARY;R2 ITS SECONDERY.e.g continuous internet access in case on of link goes down
How can i CONFIGURE like this setup?can i do load Balence?
Config like this:
active router(R1)
interface fa0/0
ip address 10.10.100.2 255.255.255.255.0
no ip redirects
ip nat inside
standby 10 priority 105 preempt
standby 10 name HSRP1
standby 10 ip 10.10.100.1
standby 10 track Fa 0/1
ip nat inside source list 1 interface fa0/1 overload
access-list 1 permit 10.10.100.0 0.0.0.255
int f0/1
ip address 202.10.10.1 255.255.255.252
ip nat outside
Standby Router(R2)
interface fa0/0
ip address 10.10.100.3 255.255.255.255.0
no ip redirects
ip nat inside
standby 10 priority 100 preempt
int f0/1
ip address 194.126.10.1 255.255.255.252
ip nat outside
THIS CONFIG WORK FOR MY SCENARIO?
10xs for ur reply & for ur examination!
Overall Rating: 5 (2 ratings)
Jon Marshall Tue, 02/20/2007 - 11:35
Hi Ali
Assuming that the clients are in the same subnet as your fa0/0 interfaces on R1 & R2
yes it looks like this config will work fine. Be aware thought that if the primary link fails all existing connections will be dropped from a user perspective as the source IP addresses will then change to new public IP address of R2's f0/1 interface.
This will not load balance though. Is that what you want or do you just wan redundancy in case the primary link goes down ?
If you want load balancing between both links you could look at Glbp. A link is attached:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_white_paper09186a00801541c8.shtml#wp1027177
Jon
purohit_810 Wed, 02/21/2007 - 09:23
Generally... In this kind of scenarion. Mean 2 Internet links and Load balancing.. people are prefering REDWARE product for solution.
Dharmesh Purohit
purohit_810 Tue, 02/20/2007 - 11:41
Yes, Global load balancing should work in that scenario.
Dharmesh Purohit
Jon Marshall Wed, 02/21/2007 - 00:21
Hi Ali
yes you can track interfaces with GLBP. Basically you give each router a weighting and if the tracked interface goes down you can reduce the weighting so that this router is not used to forward traffic.
There is an example of how to do this in the document i sent.
Let me know if i can help any more
Jon
