CAR Problem CCM 5.0.4
Feb 20th, 2007
Hi, i have a problem for CAR reports.
This is the error, pls see the attachment
I has been the CAR configuration checklist, but still not work. Any idea?
nikger1980 Tue, 03/20/2007 - 03:38
Hello Christian.
Go to the Administration menu , system-->Service Parameter Configuration.
check the "CDR Enabled Flag " as true and the "Call Diagnostics Enabled " as "enabled only when CDR enabled Flag is true" (disabled by default).
jjiles Thu, 03/29/2007 - 10:52
I have a similar problem. We migrate from 4.1 (windows) to 5.0(4) on Linux. We tried migrating the CDR records to the new system, but I cannot see any reference from CAR. You mentioned that the CDR will not migrate. I can deal with that, but for some reason I cannot get CDR going for records after the migration. I have CDR flag and Call Diagnostic options enabled. What would be the location for the CDR flat files under CCM5.0??
I would like to check if the files are being created or not.
Thanks for any info.
mohsenlotfi Mon, 04/02/2007 - 02:45
Have you find a way to resolve your issue with CAR ?
Because i have similar problem with CAR on CCM 5.0(4)
the CDR LOAD even log shows Unsuccessful for any attempt
I am sure about my CAR parameter configuration and since access to CCM DB is limited I dont know how to resolve this issue
