catalyst 4500 ios upgrade question
Answered Question
Feb 20th, 2007
I am currently running cat4000-i9s-mz.122-25ewa6 on a catalyst 4503 supervisor II plus TS, which doesnt support SSH management. Will upgrading to one of the following do the job:
12.2.31-SGA1 (ED)
12.2.31-SGA (ED)
12.2.31-SG1 (ED)
12.2.31-SG (ED)
12.2.25-SG1 (ED)
12.2.25-SG (ED)
I want to keep the same functionality but just add ssh. Also, which one should I go with, the latest 12.2.31-SGA1 (ED)? And can someone explain what the letters represent, EWA6, SG, SGA1, ED, etc. Thanks for the help.
Correct Answer by hoogen_82 about 9 years 7 months ago
The image that i have suggested is the same one but just with an addition of ssh support. The image that you have got is defferred. So its good if you upgrade.
There is no specific advantage or disadvantage between the three atleast not much between the image you have and what i have given. The third one is ipbase with some more additional features. You can go through the feature lookup for that.
Hoogen
Please do rate if my post has helped you :)
Overall Rating: 5 (1 ratings)
glen.grant Tue, 02/20/2007 - 13:42
Any of those images that has k9 in the image name should support ssh , must have k9 in the image name.
hoogen_82 Wed, 02/21/2007 - 23:37
Your ideal image should be cat4000-i9k91s-mz.122-25.EWA8.bin and also do ensure you have 32 mb flash and 256 mb dram. This would ensure same functionality.
Follow the link
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosresult.cgi?get_crypto=&data_from=&hardware_name=CAT4500-SUP2-PLUS-TS&software_name=BASIC%20L3%203DES%20%28RIP%2CST.ROUTERS%2CIPX%2CAT%29&release_name=12.2.25-EWA8&majorRel=12.2&state=:HW:RL:SW&type=Early%20Deployment
But if you do want to get SG images you can use this cat4500-ipbasek9-mz.122-31.SGA1.bin but this requires higher flash 64mb and dram is still 256mb.
The link
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosresult.cgi?get_crypto=&data_from=&hardware_name=CAT4500-SUP2-PLUS-TS&software_name=IP%20BASE%20SSH&release_name=12.2.31-SGA1&majorRel=12.2&state=:HW:RL:SW&type=Early%20Deployment
Hoogen
Do rate if this helps :)
rhopkins_nci Thu, 02/22/2007 - 05:51
Thanks for the great info, just for curiosity, what is the difference in functionality and features of these images including the one Im running currently. Is the Basic L3 DES the same as my current one but the addition of ssh? Are there any advantages b/w the three? What exactly is the IP Base? Sorry for all the questions, new to this and just trying to learn. Thanks again.
Correct Answer
hoogen_82 Thu, 02/22/2007 - 09:59
Hoogen
