PAT Multiple PPTP or Not
Answered Question
When searching cisco.com for configuration examples on allowing PPTP through an PIX or an ASA I found the term PAT for Point-to-Point Tunneling Protocol (PPTP) in the 6.3 release notes. It is specifically for allowing multiple PPTP connections through the PIX.
Now when I look for configuration examples, everything says that it isn't possible to have multiple PPTP tunnels through a pix or asa.
So which is are the release notes right or the config examples?
Has this feature been dropped in 6.3?
Brian
Release Notes for 6.3:
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2030/products_data_sheet09186a0080148714.html
Config Example:
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094a5a.shtml#ts1
Correct Answer by kaachary about 9 years 7 months ago
Correcting myself..
When the PPTP server is behind a patted ip address, the connection would simply not work.
With clients behind a patted ip address, only first connection would work. Multiple connections would not work with out one to one translation.
I apologise for the wrong information.
HTH,
-Kanishka
Overall Rating: 0 (1 ratings)
kaachary Wed, 02/21/2007 - 02:39
The part of the config example you are talking about, where it says that multiple pptp connection are not possible through PAT, is specifically for the scenario :
"PPTP with the Client Outside and the Server Inside"
When PPTP server is behind a patted ip address, only one connections is possible, and this is true for all Cisco devices.
When clients are behind a patted ip address, you need to add "fixup protocol pptp 1723" on the PIX for multiple PPTPT connections.
HTH,
-Kanishka
Correct Answer
kaachary Wed, 02/21/2007 - 03:31
Correcting myself..
HTH,
-Kanishka
