VPN is up but no traffic flows between PIX and Juniper FW
Feb 20th, 2007
Hi There,
I have configured site-to-site VPN between PIX and Juniper FW; I am checking the VPN link status and it is showing as up when monitoring via ASDM, however I cannot ping or access to the remote site. I am already having 2 ACLs allowing traffic both ways but I am not able to ping or access the remote network!
I noticed one weired thing when checking the pre-shared key through the ASDM, which is that sometimes the pre-shared key keeps changing and I keep forcing it manually to the correct value. I am using ver 7.2(2). But again, please bear in mind that I see the VPN connection as up!
Any clues?
Haitham
ROBERTO TACCON Sun, 02/25/2007 - 04:55
maybe the following info help you
* Use the packet-tracer option.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807c35e7.shtml
packet-tracer option in the ASA.
ciscoasa#packet-tracer input inside tcp 192.168.1.50 1025 172.22.1.1 http
The most important output of the packet-tracer command is the last line, which is Action: allow.
* Most Common IPSec VPN Troubleshooting Solutions
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
