CiscoSecure Services Client and Domain Logon
Feb 20th, 2007
I'm attempting to get CSSC to perform an authentication against our ACS database using Single Sign On. However, I need the username to be passed to ACS as DOMAIN\USERNAME whereas CSSC appears to pass just the USERNAME portion. ACU/ADU have the ability to include the domain name in the logon, but I can't see a similar option in ACS. (The DOMAIN portion needs to be included as some users already exist in the ACS database as token-based users with the same USERNAME).
The documentation suggests it is possible to alter how the SSO details are passed to the authentication server, but I cannot find what the documentation refers to as the "SSO text entry box".
sbilgi Mon, 02/26/2007 - 14:15
You need to enable this both on the ADU for the client side and also on the ACS server.
csannedhi Mon, 02/26/2007 - 20:33
Sounds like you want to submit the user credentials as domain\username. This makes me assume that you are using some sort of "external" user database. If it is a Windows database check the "Domain List" option.
csannedhi Mon, 02/26/2007 - 20:35
Also check the ACS for failed logins. The explanation will tell you what to do.
Trending Topics - Security & Network
