MOH no more resources available
Feb 20th, 2007
I have setup multicast MOH to remote sites using the routers to provide the MOH, this has worked for some time ok, but now I get the MOHNoMoreResorcesAvailable message in the event log when somebody is put on hold.
I reload the Callmanager that has the MOH server, it seems to work once then get messages again
the unicast MOH is ok( uses another Callmanager)
anybody any ideas
mchandak Wed, 02/21/2007 - 06:58
U should use RTMT, Perfmon to check if the sessions are being released or not after MoH is being played
Richard Bradfield Wed, 02/21/2007 - 23:22
thats not the problem, I configured 250 Multicast streams, and there is still 250 streams available, just the outof resources counter increments eveytime
mchandak Thu, 02/22/2007 - 05:53
If u see MoH resources available, then the phones/device which is initiating MoH does not have access to the MoH server which has multicast enabled. Can u collect CCM Traces and IP Voice Media Streaming App Detailed traces for a test call ??
