Link dropping off
Feb 20th, 2007
We are currently using 3560's, we are having intermitant connections drop off, is there a tool or debug I can run on an effected link to try accertain what is going on. The interfaces are dropping off maybe once a day, 3-5 interfaces on a single switch.
Thanks for any advice
spremkumar Tue, 02/20/2007 - 21:09
Logs available in your Cisco 3560 can provide vital info on the why the ports are dropping.
You can verify the same to start the troubleshooting process...
regds
jain.nitin Tue, 02/20/2007 - 22:31
Hi, Check the duplex & speed settings on thoes ports & more importantly check what are the devices connected on these port, r they able to negotiate speed & duplex.
I suggest u if it is connected to server/switches then configure speed & duplex manually on these ports.
If it helps, please do rate.
kpmgnz Wed, 02/21/2007 - 12:21
Hi here is the output from show logging:
NZAKL2NET3#show logging
Syslog logging: enabled (0 messages dropped, 31 messages rate-limited, 0 flushes
, 0 overruns, xml disabled, filtering disabled)
Console logging: level debugging, 327 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 357 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Trap logging: level informational, 331 message lines logged
Log Buffer (4096 bytes):
/13, changed state to up
000324: *Mar 4 23:42:04: %SYS-CLUSTER_MEMBER_11-5-CONFIG_I: Configured from con
sole by vty0 (10.150.0.210)
000325: *Mar 4 23:43:12: %SYS-CLUSTER_MEMBER_11-5-CONFIG_I: Configured from con
000326: *Mar 7 02:19:17: %LINEPROTO-CLUSTER_MEMBER_11-5-UPDOWN: Line protocol o
n Interface FastEthernet0/13, changed state to down
000327: *Mar 7 02:19:18: %LINK-CLUSTER_MEMBER_11-3-UPDOWN: Interface FastEthern
000328: *Mar 7 02:19:20: %LINK-CLUSTER_MEMBER_11-3-UPDOWN: Interface FastEthern
et0/13, changed state to up
000329: *Mar 7 02:19:21: %LINEPROTO-CLUSTER_MEMBER_11-5-UPDOWN: Line protocol o
n Interface FastEthernet0/13, changed state to up
000330: *Mar 7 02:20:00: %LINEPROTO-CLUSTER_MEMBER_11-5-UPDOWN: Line protocol o
000331: *Mar 7 02:20:01: %LINK-CLUSTER_MEMBER_11-3-UPDOWN: Interface FastEthern
000332: *Mar 7 02:20:03: %LINK-CLUSTER_MEMBER_11-3-UPDOWN: Interface FastEthern
000333: *Mar 7 02:20:04: %LINEPROTO-CLUSTER_MEMBER_11-5-UPDOWN: Line protocol o
000334: *Mar 7 05:50:38: %LINEPROTO-CLUSTER_MEMBER_11-5-UPDOWN: Line protocol o
000335: *Mar 7 05:50:40: %LINEPROTO-CLUSTER_MEMBER_11-5-UPDOWN: Line protocol o
000336: *Mar 7 05:50:49: %LINEPROTO-CLUSTER_MEMBER_11-5-UPDOWN: Line protocol o
000337: *Mar 7 05:50:50: %LINK-CLUSTER_MEMBER_11-3-UPDOWN: Interface FastEthern
000338: *Mar 7 05:50:52: %LINK-CLUSTER_MEMBER_11-3-UPDOWN: Interface FastEthern
