Cisco 7940G
Feb 20th, 2007
Is the newest SIP firmware for the 7940G XML based like the 79x1G series phones?
Paolo Bevilacqua Tue, 02/20/2007 - 23:54
You mean Java based?
No, it's not.
XML instead is in all the models.
Remember to rate useful posts.
Frozen2007 Wed, 02/21/2007 - 00:03
Sorry, I should rephrase. I ment to ask if the configuration files on the 7940 and 7960 phones were XML based like the 79x1 and 7970.
Paolo Bevilacqua Wed, 02/21/2007 - 01:23
Yes, as I said all all the cisco phones uses XML both for configuration and display/applications, with the exception of 7902/06/12 that uses a different format of configuration files.
Frozen2007 Wed, 02/21/2007 - 01:25
The last SIP firmware version I had on a 7940 was 8-4-0 and the config file was not XML based - I was wondering... Also, do you know if the 7940G supports symmetrical NAT?
