IOS FAXMAIL TROUBLESHOOTING
I have an h323 IOS with the following configuration to do DID for both incoming calls to IP phones and to FaxMail (onramp)
translation-rule 10
Rule 0 ^2300 5000
Rule 1 ^2301 1010
call application voice onramp flash:app_faxmail_onramp.2.0.1.3.tcl
voice-port 3/0:0
translate called 10
timeouts call-disconnect 1
dial-peer voice 5000 voip
destination-pattern 5...
voice-class codec 1
session target ipv4:172.16.128.252
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
dial-peer voice 2301 mmoip
application fax_on_vfc_onramp_app out-bound
destination-pattern 1010
information-type fax
session target mailto:[email protected]
dial-peer voice 999 pots
incoming called-number .
direct-inward-dial
port 3/0:0
dial-peer voice 9999 pots
application onramp
direct-inward-dial
port 3/0:0
CALLES FROM PSTN WHICH ARE FOR 2300 ARE SENT FIRST TO PEER 999 AND THEN FOR VOIP 5000 CALL OK.
BUT CALLS TO (DNIS) 2301 (1010) DO NOT ENTER PEER 9999 WITH APP ONRAMP, INSTEAD GO TO 999 AND THEN GET STUCKED ON VOICE CONTROLLER.
IF I ENABLE FOR PEER 999 APP ONRAMP THEN I GET FAX TONE FOR 2301 (1010) BUT CALLS TO 2300 (5000) THEN GET STUCKED
Any clue?
