CCM 4.1(3) routing calls based on calling number
Feb 21st, 2007
Hello
Is it possible to route calls by calling number in CCM? For example. Inbounds calls with calling prefix 0034 route to extension 101 and calls with the rest of prefix route to extension 102 ?
I read some threads to do the same but talk about scripts for CRS.
In IOS is possible to do this scenario, but in CCM ......
lpezj Wed, 02/21/2007 - 00:40
Try to use a Translation Pattern to do that.
Hope this helps,
Juan Luis
atorresmolina Wed, 02/21/2007 - 01:41
Thanks Juan Luis
I think translation pattern work before CCM route decision and based on called number. The result of the translation (the translated called number) go to the CCM router decision and finally CCM route the call.
How can I do routing by calling number with translation pattern?
Thanks a lot
aalejo Wed, 02/21/2007 - 05:10
Dear Sr
Using only CCM, is not posible to route calls or do any transformation using ANI number.
Alex
mchandak Wed, 02/21/2007 - 07:04
On CCM, you cannot route using Calling Number. It can only be done on a H.323 Gateway. CM always routes using Calling number.
aalejo Thu, 02/22/2007 - 06:51
For routing a call using the calling number you must match an incoming call leg using a calling number. This is done easyly using answer-address or destination-pattern for incoming dial-peer.
After you match an incoming leg yo can apply cor rules or simply do some translation pattern transformations for selecting outgoing dial-peer.
Then you select outgoing leg using calling number and you route the call using the calling number.
For this to happens you must remember that incoming called-number matching have more priority that answer-addres or destination pattern for incoming call leg. Then no incoming called-number should match.
Alex
atorresmolina Thu, 02/22/2007 - 07:26
Hola Alejandro
Sorry for my last question, I confused h323 gateway (voice router) with the h323 gateway device in CCM.
I read your answer in CVOICE.
The calling number ANI with answer-address is useful when you want to match calls based on
the originating calling number. For example, when a company has international customers who
require foreign-language-speaking agents to answer the call, the call can be routed to the
appropriate agent based on the country of call origin.
For this reason I thought could be possible do calling number routing in CCM.
Thanks very much for your explanation
