GLBP
HI EXPERTS!
If we 2 routers runing GLBP for wan redundancy.this is the config for the 1st active router:
ACTIVE-ROUTER 1
interface fastethernet 0/0
ip address 10.10.100.2 255.255.255.0
glbp 10 ip 10.10.100.1
glbp 10 forwarder preempt delay minimum 60
glbp 10 load-balancing host-dependent
glbp 10 preempt delay minimum 60
glbp 10 priority 254
glbp 10 timers 5 18
glbp 10 timers redirect 600 7200
glbp 10 weighting 110 lower 95 upper 105
glbp 10 weighting track 2 decrement 5
track 2 interface f0/1 ip routing
waht could be the config for the Standby router(ROUTER 2) based on the first input?
STANDBY-ROUTER 2
Overall Rating: 5 (3 ratings)
Jon Marshall Wed, 02/21/2007 - 03:47
Hi Ali
First i think you need to make a change to your active router config.
i think you probably want to change
track 2 interface f0/1 ip routing to
track 2 interface f0/1 line-protocol
You also need to adjust your weightings. If f0/1 goes down it will not switch because you are only taking 5 off the weighting and this does not take it below 95.
So change
glbp 10 weighting track 2 decrement 5 to
glbp 10 weighting track 2 decrement 20
110 - 20 = 90 which is less than your lower threshold of 95.
For the other router
ip address 10.10.100.3 255.255.255.0
glbp 10 priority 100
glbp 10 timers 5 18
I hope this works -please let me know if you have any problems.
Jon
HI JON!
SO THE FINAL CONFIG AFTER UR CHANGE COULD BE LIKE THIS:
ACTIVE-ROUTER 1{AVG}
interface fastethernet 0/0 ip address 10.10.100.2 255.255.255.0
glbp 10 timers 5 18
STANDBY-ROUTER 2{AVF}
glbp 10 timers 5 18
ANY COMMENTS?
10XS
Jon Marshall Wed, 02/21/2007 - 04:36
Hi Ali
You would need a default route on R1 & R2 pointing to the releavant ISP wireless address but your clients will be fine.
Jon
Jon Marshall Wed, 02/21/2007 - 06:03
Hi Ali
If the links are P2P links then you can use either interfaces or ip addresses as next hop. if not then use IP addresses.
As for Glbp config - looks fine to me. You might want to add a "glb 10 preempt ..." command on R2 but it won't make any difference really as it has a lower priority anyway.
Let me know how it goes
Jon
