VG224 SRST
Feb 21st, 2007
Good day!
There is router 2851 with SRST and vg224. VG224 at loss CCM does not move to SRST, but ip phone 7940 connected to 2851 works correct without CCM. Where mistake in adjustment vg224?
See attachment (c2851,vg224)
volgaprbb Wed, 02/21/2007 - 08:57
I see at event viewer on CCM:
Event Type: Error
Event Source: Cisco CallManager
Event Category: None
Event ID: 3
Date: 2/21/2007
Time: 7:35:47 PM
User: N/A
Computer: CC-CCM1
Description:
Error: DeviceTransientConnection - Transient connection attempt.
Connecting Port: 2000
Device name [Optional].: AN19E8B9B7DD400
Device IP address.: 192.168.39.2
Device type. [Optional]: 30027
Reason Code [Optional].: 1
App ID: Cisco CallManager
Cluster ID: CC-CCM0-Cluster
Node ID: 192.168.20.239
Explanation: A connection was established and immediately dropped
before completing registration. Incomplete registration may indicate
a device is rehoming in the middle of registration. The alarm could
also indicate a device misconfiguration, database error, or an
illegal/unknown device trying to attempt a connection.
Recommended
Action: No action is required if this event was issued as a result
of a normal device rehome..
volgaprbb Wed, 02/21/2007 - 09:03
And I see on VG224:
debug sccp packets
*Mar 2 19:37:32.333: sccp_print_hex_msg: Len:28 Hex:14 00 00 00 00 00 00 00 2C 00 00 00 4B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Mar 2 19:37:32.333: sccp_transmit_msg: sending on socket 0
*Mar 2 19:37:32.365: sccpapp_process_socket_events: appl_type 4, soc_fd 0, soc0, swb_soc -1
*Mar 2 19:37:32.365: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type4, eve 4, state 3
*Mar 2 19:37:32.365: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
*Mar 2 19:37:32.365: sccp_get_control_message: bytes_to_read 36, bytes_read 36, appl_total_bytes 36, appl_bytes_read 36, soc_read_mode 1, soc 0
*Mar 2 19:37:32.365: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 36
*Mar 2 19:37:32.365: sccp_parse_control_msg: msg_ptr 631CBEBC, msg_len 36, msg_id 157
*Mar 2 19:37:32.365: SCCP(AN19E8B9B7DD400)rcvd RegisterRejectMessage
*Mar 2 19:37:32.365: sccp_parse_control_msg: rcvd register rej, reason: Error:DB Config
I have got problem with SCCP and after CCM link failed, mgcp on vg224 failed too. I try to adjust service sctapp on dial-peer, but it is not work, since SCCP failed.
volgaprbb Wed, 02/21/2007 - 22:44
c2800nm-spservicesk9-mz.124-4.T3.bin
vg224-i6s-mz.124-2.T5.bin
