CSM cookie insert expiration
Feb 21st, 2007
We see that -when using the cookie insert stickiness method- the cookie expires jan 1st, 2010. Does anyone know how to change this expiration date?
thanks for your replies,
Benoit
Overall Rating: 5 (1 ratings)
a-vazquez Tue, 02/27/2007 - 07:07
The only option is the 'variable' to set the expiration date.Use the command variable COOKIE_INSERT_EXPIRATION_DATE to change the expiration time and date.
bvandromme Fri, 03/02/2007 - 02:33
Ok, thanks for your answer. This helps me a lot. Do you happen to know what will be the result if I enter an expiration date in the past?
