After PIX upgrade from 6.3 to 7.2(2) VPN doesn?t work
Feb 21st, 2007
Hi There,
I have configured site-to-site VPN between PIX and router 871. After upgrade to version 7 , I am not able to access the remote network. I am using ver 7.2(2) in the pix and IOS ver 12.4(6)T2 in the router. The ACLs for no nat and encryption are :
access-list encryp permit ip 172.16.0.0 255.240.0.0 192.168.130.0 255.255.254.0
access-list encryp permit ip 192.168.0.0 255.255.255.0 192.168.130.0 255.255.254.0
access-list nonat permit ip 172.16.0.0 255.240.0.0 192.168.128.0 255.255.128.0
access-list nonat permit ip 192.168.0.0 255.255.255.0 192.168.128.0 255.255.128.0
Is possible that the pix OS ver 7 do not support this ACLs type (IP class B with mask /12 or IP class C with mask /17 ??
Thx
daviddtran Wed, 02/21/2007 - 06:08
Hi c-quinteros,
Whoever designed the Pix firewall should be
shot. It's so F! stupid. But enough of my
ranting.
I ran into the same problem you have before
when upgrading from 6.3(5) to 7.2(2). You
need to do this for it to work:
tunnel-group DefaultRAGroup ipsec-attributes
isakmp ikev1-user-authentication (outside) none
keep in mind that these are "hidden" command.
WTF!
for version 7.1(2):
tunnel-group DefaultRAGroup general-attributes
authentication-server-group (outside) none
Good luck.
David
CCIE Security
