how to create a virtual template
Feb 21st, 2007
Can someone tell me how to create a virtual template?
I need to setup one for the ISDN users to dial in to our network.
Does my Virtual-Template config get created around my Serial config?
I have dialers created for my clients to dialin as ISDN backups.
Thanks for help.
Here is the config for my serial interface:
interface Serial1/1:15
description isdn-pri
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool-member 1
dialer pool-member 200
isdn switch-type primary-net5
isdn incoming-voice modem
isdn calling-number 1900
peer default ip address pool dialin
no cdp enable
ppp authentication pap chap callin
bradlesliect Thu, 02/22/2007 - 08:21
virtual profile?Instance of a unique virtual access interface created dynamically when certain users call in and torn down dynamically when the call disconnects. A specific user's virtual profile can be configured by a virtual template interface, user-specific interface configuration stored on an AAA server, or both a virtual template interface and user-specific interface configuration from AAA.
Config change:
Conf t
Interface virtual-template 1
ip unnumbered Ethernet 0
Virtual-profile virtual-template 1
.....my question is....how does the template know which PHYSICAL interface to use? We have a PRI that is configured to a serial interface.
So what happens when an ISDN user dials in bearing in mind that we have IAS running which does the authorization.
