Vlan 1 on 2924-xl
Feb 21st, 2007
I have tried to block Vlan 1 on a port fa 0/1 trunk of a Catalyst 2924-XL.
I have entered :
switch#(config-if)switchport mode trunk
switch#(config-if)switchport native vlan 2
switch#(config-if)switchport trunk allowed vlan 2
Unfortunately I see again vlan 1 on this trunk
Can I block it on Catalyst 2924-XL ?
bets regards
Lorenzo
lformelli Wed, 02/21/2007 - 23:28
I know, but with C2950-24 I can do it,
I can block vlan 1 on trunk to any port
fastethernet, provided that I configure another native vlan for that port.
Can you tell me about it ?
Best regards
Lorenzo
Lorenzo, the 2900XL and 3500XL series boxes are slightly different creatures. Example:
Switch>(config)switchport trunk allowed vlan remove vlan-list
The " remove vlan-list" valid variable range is 2-1001, also the pruneeligible list accepts only 2-1001.
I don't have access to a 2900XL, but you might want to see if there's a later IOS release that addresses this.
Have you tried to Shutdown interface VLAN1 and see if it takes?
My ref:
http://www.cisco.com/en/US/products/hw/switches/ps637/products_configuration_guide_chapter09186a00800d9d3e.html
lformelli Thu, 02/22/2007 - 06:51
yes ,
it he same also if I shutdown Vlan 1.
Perhaps 2950 and 2900 are really difference.
I have installed the last IOS for my 2924-XL
but don't change never.
best regards
Lorenzo
