ws-x4148-rj45v with linksys spa942
Feb 21st, 2007
I've got some WS-X4148-RJ45V blades in a Catalyst 4506, and some Linksys SPA942 voip phones. Is there any way to get these phones to power from the 4148 blade? Perhaps force power on a port-by-port basis? Or will I need to replace them with 4248s?
Anthony
purohit_810 Thu, 02/22/2007 - 15:10
Hi Anthony,
There is not need to supply external power supply.
Is phone cannot get power from switch port,
You can configure and test following way,
Switch# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)# interface fastethernet 5/8
Switch(config-if)# power inline auto
Switch(config-if)# end
This example shows how to verify the inline power configuration for the Fast Ethernet interface 5/8.
Switch# show power inline fastethernet 5/8
Interface Admin Oper Power ( mWatt ) Device
FastEthernet5/8 auto on 400 cisco phone device
Switch#
If still you are facing problem please let me know.
Dharmesh Purohti
