changing static nat on asa
Feb 21st, 2007
Hi i need to change static association for a public ip to internal ip
right now i have following statment.
static (dmz,outside) 66.xx.xx.xx 192.168.50.91 netmask 255.255.255.255
it needs to be changed to
192.168.51.14 netmask 255.255.255.255
what should I need to do ?
do i need to add no statment to previous statement and execute new ?
Jon Marshall Wed, 02/21/2007 - 07:21
yes you should do
no static (dmz,outside) 66.xx.xx.xx 192.168.50.91 netmask 255.255.255.255
then
You will then need to clear the xlate. Do not just enter "clear xlate" as it will remove all the xlates which will break all existing connections through the ASA.
Do
clear xlate global 66.xx.xx.xx
Jon
